9 years agoQuartus 16.1 crashes when compiling on Ubuntu 14.04
Hi all, I am trying to compile a test project on Quartus II, namely the Golden Hardware Reference Design for the Terasic DE1-SOC board, but it keeps crashing when compiling the design. The Anal...
9 years agoThank you for your reply, The Smith. I didn't know that tool, and it resulted very useful.
After using it and generating again the Qsys project, I run the Analysis & Synthesis and worked correctly!! However, after compilation, a different crash happened, with the following report: problem details Error: *** Fatal Error: Segment Violation at 0x7f8da644d470 Module: quartus Stack Trace: End-trace Executable: quartus Comment: None system information Platform: linux64 OS name: Ubuntu 14.04.5 OS version: 14 quartus prime information Address bits: 64 Version: 16.1.0 Build: 196 Edition: Lite Edition Meanwhile, I installed the quartus version 16.0 update 2, and the previous crashes stopped happening. Thus, I think that despite the project was compiled correctly in 16.1, I will turn to 16.0 as it seems more stable and I was able to compile the project without cleaning it before, and any problems were reported. Thank you, Javier.
