9 years agoQuartus 16.1 and Win7-64
While compiling a project on Windows 7 64-bit I get an exception with the following details
--- Quote Start --- problem details error: Internal Error: Sub-system: ATCL, File: /quartus/ccl/atcl/atcl_root.cpp, Line: 986 ------------------------------------- Error found while sourcing: c:/intelfpga_lite/16.1/quartus/common/tcl/internal/init/fitter.pkg_info ------------------------------------- ERROR: Can't load library: c:\intelfpga_lite\16.1\quartus\bin64\comp_fit2.dll. The operating system reports the following error: %1 is not a valid Win32 application. Stack Trace: 0x46ad: err_report_internal_error + 0x2d (CCL_ERR) 0xe828: atcl_initialize_pkg_info + 0x448 (ccl_atcl) 0xf40a: atcl_initialize_quartus_interpreter + 0x9a (ccl_atcl) 0xe1c2: atcl_get_interpreter + 0x42 (ccl_atcl) 0x2de52: ACF_MANAGER_STORAGE_REAL::ACF_MANAGER_STORAGE_REAL + 0x5d2 (db_acf) 0x26e7e: ACF_MANAGER::internal_open_create_project + 0xa9e (db_acf) 0x28984: ACF_MANAGER::open_project + 0x7b4 (db_acf) 0x685ef: QHD_ROOT_IMPL::open_acf_if_needed + 0xbf (comp_qhd) 0x679be: QHD_ROOT_IMPL::initialize + 0x11e (comp_qhd) 0x37204: qcu_run_tcl_option + 0x3d4 (comp_qcu) 0x160aa: qexe_run + 0x39a (comp_qexe) 0x16e51: qexe_standard_main + 0xc1 (comp_qexe) 0x2233: qfit2_main + 0x73 (quartus_fit) 0x13328: msg_main_thread + 0x18 (CCL_MSG) 0x14b0e: msg_thread_wrapper + 0x6e (CCL_MSG) 0x15b00: mem_thread_wrapper + 0x70 (ccl_mem) 0x12a11: msg_exe_main + 0xa1 (CCL_MSG) 0x287e: __tmainCRTStartup + 0x10e (quartus_fit) 0x1652c: BaseThreadInitThunk + 0xc (kernel32) 0x2c520: RtlUserThreadStart + 0x20 (ntdll) End-trace executable: quartus comment: None system information platform: windows64 os name: Windows 7 os version: 6.1 quartus prime information address bits: 64 version: 16.1.0 build: 196 edition: Lite Edition --- Quote End --- Is there any fix for the problem?3 Replies
Its a crash - you will have to raise a mysupport ticket with altera.
--- Quote Start --- Its a crash - you will have to raise a mysupport ticket with altera. --- Quote End --- If change to Windows 7 32-bit - would it fix the problem? - Altera_Forum
No - Quartus from v15 onwards only supports 64bit OSs
You will need to raise a mysupport ticket.
