11 years agoQuartus 15 compilation deterministically hangs for several seconds
Hi together,
I currently have Quartus 15.0 update 2 installed on Fedroa 22. Whenever I compile any project, the compilation keeps hanging at certain places, e.g. after the elaboration is done it hangs for about 20 seconds before starting the timing-driven synthesis. The CPU is idle during that time. It also keeps freezing when double-clicking a file in the project navigator; after about 20 seconds (I timed it) the Quartus editor opens. All file operations in all other applications on my system run virtually instantaneously, it's only Quartus that seems to take a break during file operations. This happens every time, with every project. When I compile stuff on Quartus 13.0sp1, everything runs smooth, including opening files. So first I thought, okay, there's some issue with Quartus 15, but I recently installed Quartus 15 on Xubuntu, and there it runs smooth! Both Quartus 13.0sp1 on my system and Quartus 15.0 on Xubuntu need several minutes less, which makes quite a difference (about factor 3 in total) when you want to compile with only about 1k registers. Am I the only one who experiences these delays? Any idea how to solve that? I know this issue is to be considered minor, but waiting 20s to open a file to fins the line that the compiler complains about, that is really annoying, and I'd love to fix that. Best regards, GooGooCluster12 Replies
Has anyone figured this out yet? I have found that if I disable Signaltap, the long delay is gone... But I need signaltap.
as the previous posts suggest, turning off the internet connection helps in particular cases. Also, v15.1 doesn't suffer this problem any more, at least not on my PC. Best regards, GooGooCluster
