11 years agoQuartus 15 compilation deterministically hangs for several seconds
Hi together, I currently have Quartus 15.0 update 2 installed on Fedroa 22. Whenever I compile any project, the compilation keeps hanging at certain places, e.g. after the elaboration is done i...
11 years ago --- Quote Start --- You're right, it was a small design with 270 registers, and the numbers are minutes:seconds. At work I'm dealing with larger design, but there I don't suffer from that problem, so I have no data for large designs. I guess the little delays I encounter on my Fedora installation would get lost in the noise then. That's particularly interesting, because I only saw the issue on Quartus 15; with Quartus 13.x I never observed any hangs. Okay, it's not Quartus 10 or 11, and again I only do small designs here on this installation, so no good correlation data :) --- Quote End --- I am having the same issue with my compilation. It takes nearly 10 min for full compilations. Have you guys found any work around?
