11 years agoQuartus 15.1 crashing when going for Tools...License Setup
It just goes as "core dumped" when you run in terminal. I bypassed the bash script and ran quartus straight into gdb and got this backtrace: # 0 0x00007fffadc8dcc9 in __GI_raise (sig=s...
10 years agoThat is exactly what they said: "Although Ubuntu is not supported, we are going to look into the issue".
Well THANK YOU Altera for extending your misprize to my troubled *** so we can fix a nasty bug on YOUR software. It also shows your disconnect with the very own community that embraces you most - because if you relied on Windows you'd be dead beef at this point. On a less sarcastic note, if you look closely, it seems Quartus calls qFatal() on libQtCore.so.4 from PRDQ_PTE::update_line_edit(). This was not just an accidental crash, Quartus purposely aborted this process. # 4 0x00007fdf0260f715 in qFatal(char const*, ...) () from /home/sun/altera/15.1/quartus/linux64/libQtCore.so.4 # 5 0x00007fde6496f4bf in PRDQ_PTE::update_line_edit() () from /home/sun/altera/15.1/quartus/linux64/libprj_prdq.so
