10 years agoQuartus 13SP1 web license download fails
I'm running QuartusII 13SP1 for the CycloneII in Windows 8.1 (with a 4k screen).
When I start Quartus I get an option box to get a license file. I select "Connect to the Altera License Center" and a browser opens with 404-Page not found and in the url "https://www.altera.com/common/sitemap404.tablet.highResolutionDisplay.html". It is being redirected from "https://mysupport.altera.com/quartus/license.asp". I have tried to set the resolution to HD but that doesn't change anything. Am I choosing the wrong option or... Probably a side effect of this is that the device information I have downloaded and installed with the Device Installer, is not showing in the software... Thanx very much. Marc12 Replies
I believe cost is a major concern in all the projects.
you have to go for newer one, unless you remained to stick on those feature and application you already felt sufficient, otherwise, you won't get any new example from Altera already for older parts
