14 years agoIt turns out that tbbmalloc is the problem for the install too. After Quartus installs, the installer runs quartus to install the device support. That's when Quartus crashes.
What I did was watch the files as they were installed. when tbbmalloc* appeared in quartus/linux, I immediately moved them to the side. With that kludge, I was able to get through the entire installation. There must be a more elegant solution but this way does work. If there was a single file that was the source of only tbbmalloc*, I could just remove it before starting the installer but I don't know what that file would be (if there even is such a file).
