13 years agoHi,
I suggest two things to check - first maybe the best is to "upgrade" to the latest quartusII WebEdition as the 12.1 comes with a 64Bit "version" of the WebEdition to use on 64Bit systems. This solved also the often discussed issue of USB - Blaster and JTAG Server installation on 64Bit OS. Besides this have you checked the JTAG chain working properly at all - ok, should as the device seems to be detected...
