13 years agoQuartus 11.1sp2 -> 12.0sp2 RAM fit error
I have an Arria II design that fits ok when compiled under 11.1sp2. However, under 12.0sp2 it cannot fit all the RAM into the chip. I figured out that in 12.0 it does not use any MLABs and runs out of M9Ks. 11.1 does use MLABs to fit the RAM into the chip. I checked all the usual suspects as far as RAM fitting options. I compared the settings side by side between 11.1sp2 and 12.0sp2 and they are the same. I made sure that the paused RAM feature is set to "Don't Care". Any idea what I could check next? On the fitter report, all of the RAMs have Type is set to AUTO. Thank you!
