Altera_ForumHonored Contributor15 years agoQuartus 10 in Windows 2008 Server Hi all, I installed the new version of on windows 2008 server. I copied a project generated from 9.1. When I run sopc builder and click generate, it gets hung at the "starting PTF elabor...Show More
Altera_ForumHonored Contributor15 years agoQuartus II isn't officially supported on Windows Server, not sure its tested there at all
Recent DiscussionsQuartus 20.1std compilation fails for Quartus map - Device 10AS057K2F40I1SGIs Quartus Prime Pro 22.4 Compatible with Stratix 10 NX Series Device?Timing analysis - long combinational pathQuartusPro 25.3 Crashed after using the Signal Tap Logic AnalyzerDuplicate_hierarchy_depth / duplicate_register
