14 years agoQuartus 10.0 bug?
Hi again Guys,
I have a little issue. Attached file compiles fine with Q 10.1, however on Q 10.0 I'm getting following warnings after analysis and synthesis: Info: Elaborating entity "rom1" for the top level hierarchy Warning (10873): Using initial value X (don't care) for net "datar" at rom1.vhd(18) Warning (10873): Using initial value X (don't care) for net "datai" at rom1.vhd(19) Warning: Output pins are stuck at VCC or GND Warning (13410): Pin "datar[0]" is stuck at GND Warning (13410): Pin "datar[1]" is stuck at GND Warning (13410): Pin "datar[2]" is stuck at GND Warning (13410): Pin "datar[3]" is stuck at GND Warning (13410): Pin "datar[4]" is stuck at GND Warning (13410): Pin "datar[5]" is stuck at GND Warning (13410): Pin "datar[6]" is stuck at GND Warning (13410): Pin "datar[7]" is stuck at GND Warning (13410): Pin "datar[8]" is stuck at GND Warning (13410): Pin "datar[9]" is stuck at GND Warning (13410): Pin "datar[10]" is stuck at GND Warning (13410): Pin "datar[11]" is stuck at GND Warning (13410): Pin "datar[12]" is stuck at GND Warning (13410): Pin "datar[13]" is stuck at GND Warning (13410): Pin "datar[14]" is stuck at GND Warning (13410): Pin "datar[15]" is stuck at GND Warning (13410): Pin "datai[0]" is stuck at GND Warning (13410): Pin "datai[1]" is stuck at GND Warning (13410): Pin "datai[2]" is stuck at GND Warning (13410): Pin "datai[3]" is stuck at GND Warning (13410): Pin "datai[4]" is stuck at GND Warning (13410): Pin "datai[5]" is stuck at GND Warning (13410): Pin "datai[6]" is stuck at GND Warning (13410): Pin "datai[7]" is stuck at GND Warning (13410): Pin "datai[8]" is stuck at GND Warning (13410): Pin "datai[9]" is stuck at GND Warning (13410): Pin "datai[10]" is stuck at GND Warning (13410): Pin "datai[11]" is stuck at GND Warning (13410): Pin "datai[12]" is stuck at GND Warning (13410): Pin "datai[13]" is stuck at GND Warning (13410): Pin "datai[14]" is stuck at GND Warning (13410): Pin "datai[15]" is stuck at GND Info: Generating hard_block partition "hard_block:auto_generated_inst" Warning: Design contains 11 input pin(s) that do not drive logic Warning (15610): No output dependent on input pin "clk" Warning (15610): No output dependent on input pin "address[0]" Warning (15610): No output dependent on input pin "address[1]" Warning (15610): No output dependent on input pin "address[2]" Warning (15610): No output dependent on input pin "address[3]" Warning (15610): No output dependent on input pin "address[4]" Warning (15610): No output dependent on input pin "address[5]" Warning (15610): No output dependent on input pin "address[6]" Warning (15610): No output dependent on input pin "address[7]" Warning (15610): No output dependent on input pin "address[8]" Warning (15610): No output dependent on input pin "address[9]" Info: Implemented 43 device resources after synthesis - the final resource count might be different Info: Implemented 11 input pins Info: Implemented 32 output pins Info: Quartus II Analysis & Synthesis was successful. 0 errors, 47 warnings Info: Peak virtual memory: 258 megabytes Info: Processing ended: Fri Nov 4 13:47:16 2011 Info: Elapsed time: 00:00:10 Info: Total CPU time (on all processors): 00:00:10 It seems to be a Q 10.0 bug. Did you experienced this before?
