14 years agoI Agree with tricky. A test bench is the way to go.
Learning Verilog or VHDL will be a great help both in your design and test bench. I have a simple "CPU" emulator (since most of my designs have a external CPU in the system), that I use over and over again. It simply reads a hex file for some simple functions (Read/Write registers, wait for signal, etc) If you want, you could have a hex file that simulated all the inputs to the chip and use it like a vector waveform. In verilog, the $readmemh is the command to look into. Pete
