qrive1
7 years agoQuartus : Master clock could not be derived
I am working on Stratix 10 and Quartus 18.1 pro. Im using a PLL created with the IP 'IOPLL' in order to create a 40MHz clock from a 320MHz clock input from Si5341 ("pll_40"). Normally, I don't ha...
SreekumarR_G_Intel
6 years agosorry , caught into other stuff and missed out ,
Actually i am not sure why not for the both the clock, I will raise the quires to the internal team and come back to you .
Meanwhile if you find anything similar can you let me know as well so i can learn from you.
Thank you ,
Sree
