Go to Assignments -> Settings
Compilation Process settings Make sure "Run Assembler during compilation" is ticked. - Altera_Forum
--- Quote Start --- Go to Assignments -> Settings Compilation Process settings Make sure "Run Assembler during compilation" is ticked. --- Quote End --- I can confirm this is ticked and Assembler does run in the compilation process, however, no sof file is generated. - Altera_Forum
Can you check the assembler report? There should be a table of generated files, and maybe a warning in the messages if no .sof file was generated.
To generate a new sof file thanks to start assembler in quartus processing menu,
do I have to open before a specific file from my project ? because when I open my project .qpf and start assembler it doesn't work Error: Run Fitter (quartus_fit) before Assembler (quartus_asm) Error: Quartus II Assembler was unsuccessful. 1 error, 0 warnings - Altera_Forum
There was a problem with the fitter - what was the error?
--- Quote Start --- To generate a new sof file thanks to start assembler in quartus processing menu, do I have to open before a specific file from my project ? because when I open my project .qpf and start assembler it doesn't work Error: Run Fitter (quartus_fit) before Assembler (quartus_asm) Error: Quartus II Assembler was unsuccessful. 1 error, 0 warnings --- Quote End --- Try deleting the folders "db" and "incremental_db", before compiling the project. Sometimes that helps if Quartus is doing weird things. - Altera_Forum
I did what you said vhdl_world and the problem with run fitter disappeared, so it's ok.
But I have the Error: Run Analysis and Synthesis (quartus_map) with top-level entity name "top_fpga_opg_master" before running the Assembler (quartus_asm) I don't know where is the problem ? Do I have to settle something ? - Altera_Forum
--- Quote Start --- I did what you said vhdl_world and the problem with run fitter disappeared, so it's ok. But I have the Error: Run Analysis and Synthesis (quartus_map) with top-level entity name "top_fpga_opg_master" before running the Assembler (quartus_asm) I don't know where is the problem ? Do I have to settle something ? --- Quote End --- So, why don't you do that (Run Analysis and Synthesis with "top_fpga_opg_master")? Is your top module selected correctly? Otherwise go to "Project Navigator" window > Files > Right click on the correct file and "Set as Top-Level Entity". good luck! - Altera_Forum
--- Quote Start --- To generate a new sof file thanks to start assembler in quartus processing menu, do I have to open before a specific file from my project ? because when I open my project .qpf and start assembler it doesn't work Error: Run Fitter (quartus_fit) before Assembler (quartus_asm) Error: Quartus II Assembler was unsuccessful. 1 error, 0 warnings --- Quote End --- Either the fitter didn't run successfully in the previous attempt or the data base files get corrupted somehow....Please delete the db and incremental db folder and rerun the whole process till fitter. - Altera_Forum
