12 years ago --- Quote Start --- I did what you said vhdl_world and the problem with run fitter disappeared, so it's ok. But I have the Error: Run Analysis and Synthesis (quartus_map) with top-level entity name "top_fpga_opg_master" before running the Assembler (quartus_asm) I don't know where is the problem ? Do I have to settle something ? --- Quote End --- So, why don't you do that (Run Analysis and Synthesis with "top_fpga_opg_master")? Is your top module selected correctly? Otherwise go to "Project Navigator" window > Files > Right click on the correct file and "Set as Top-Level Entity". good luck!
