11 years agoQuartues 13.0 error
Hello everyone.
I downloaded Quratus II 13.0, and used it for the first time to compile a very simple and circuit which I called Myfirstprogaram_13. The compilation was successful, but after simulating the file I got the next report: Device family: MAX7000S Running quartus eda_testbench >> quartus_eda --gen_testbench --check_outputs=on --tool=modelsim_oem --format=verilog Myfirstprogaram_13 -c Myfirstprogaram_13 {--vector_source=C:/Users/Mohamed/Desktop/3100/Lab1_13/Myfirstprogaram_13.vwf} {--testbench_file=./simulation/qsim/Myfirstprogaram_13.vt} PID = 4928 ******************************************************************* Running Quartus II 32-bit EDA Netlist Writer Version 13.0.1 Build 232 06/12/2013 Service Pack 1 SJ Web Edition Processing started: Sun Jul 20 01:39:45 2014 Command: quartus_eda --gen_testbench --check_outputs=on --tool=modelsim_oem --format=verilog Myfirstprogaram_13 -c Myfirstprogaram_13 --vector_source=C:/Users/Mohamed/Desktop/3100/Lab1_13/Myfirstprogaram_13.vwf --testbench_file=./simulation/qsim/Myfirstprogaram_13.vt Generated Verilog Test Bench File ./simulation/qsim/Myfirstprogaram_13.vt for simulation Quartus II 32-bit EDA Netlist Writer was successful. 0 errors, 0 warnings Peak virtual memory: 300 megabytes Processing ended: Sun Jul 20 01:39:48 2014 Elapsed time: 00:00:03 Total CPU time (on all processors): 00:00:02 Running quartus eda_func_netlist >> quartus_eda --functional=on --simulation --tool=modelsim_oem --format=verilog Myfirstprogaram_13 -c Myfirstprogaram_13 PID = 3720 ******************************************************************* Running Quartus II 32-bit EDA Netlist Writer Version 13.0.1 Build 232 06/12/2013 Service Pack 1 SJ Web Edition Processing started: Sun Jul 20 01:39:49 2014 Command: quartus_eda --functional=on --simulation=on --tool=modelsim_oem --format=verilog Myfirstprogaram_13 -c Myfirstprogaram_13 Generated file Myfirstprogaram_13.vo in folder "C:/Users/Mohamed/Desktop/3100/Lab1_13/simulation/modelsim/" for EDA simulation tool Quartus II 32-bit EDA Netlist Writer was successful. 0 errors, 0 warnings Peak virtual memory: 300 megabytes Processing ended: Sun Jul 20 01:39:52 2014 Elapsed time: 00:00:03 Total CPU time (on all processors): 00:00:02 ******************************************************************* Running quartus modelsim >> vsim -c -do Myfirstprogaram_13.do PID = 600 ++++++++++++++++++++++++ And on the simulation flow wind I got the following message: Errors occurred during modelsim simulation. Can anyone help? Regards
