BIdro
3 years agoQuad SPI Flash programming with Quartus_hps.exe
I need to program a QSPI MICRON NOR FLASH (MT25QL512ABB) connected to the pins of the FPGA QSPI controller (5CSEMA5F31I7N). The program to be saved is the boot file for HPS.
I use the tool Em...
- 3 years ago
I solved my problem using another programmer.
At first I used Terasic Blaster USB and it did not work.
Then I tried using USB-Blaster II Altera and now I can program and verify the QSPI.
Thanks for the support.
Bryan
mabdrahi
Contributor
3 years agoHi Bryan,
Greetings, as we do not receive any further clarification/updates on the matter, hence would assume challenge are overcome. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. For new queries, please feel free to open a new thread and we will be right with you. Pleasure having you here.
Thank you,
Aliff
