BIdro
3 years agoQuad SPI Flash programming with Quartus_hps.exe
I need to program a QSPI MICRON NOR FLASH (MT25QL512ABB) connected to the pins of the FPGA QSPI controller (5CSEMA5F31I7N). The program to be saved is the boot file for HPS.
I use the tool Em...
- 3 years ago
I solved my problem using another programmer.
At first I used Terasic Blaster USB and it did not work.
Then I tried using USB-Blaster II Altera and now I can program and verify the QSPI.
Thanks for the support.
Bryan
BIdro
3 years agoHi Aliff,
I'm using Quartus Prime Standard Edition 18.1 and the program "Embedded_Command_Shell" belongs to the version 16 of the Quartus.
I'm using the Cyclone V SE 5CSEMA5F31I7N on a custom board.
The QSPI is connected to the qspi controller of the HPS.
The layout is good (lenght match, impedance). I tested it with oscilloscope.
The frequency of the QSPI clock generated is 781.25 KHz.
Bryan
