BIdro
3 years agoQuad SPI Flash programming with Quartus_hps.exe
I need to program a QSPI MICRON NOR FLASH (MT25QL512ABB) connected to the pins of the FPGA QSPI controller (5CSEMA5F31I7N). The program to be saved is the boot file for HPS.
I use the tool Em...
- 3 years ago
I solved my problem using another programmer.
At first I used Terasic Blaster USB and it did not work.
Then I tried using USB-Blaster II Altera and now I can program and verify the QSPI.
Thanks for the support.
Bryan
mabdrahi
Contributor
3 years agoHi Bldro,
May i know the quartus version are you using?
Thank you,
Aliff
