12 years agoQSYS system generation (ip-generate) dependency checking
Hello All,
Our build system is automating the QSYS system generation with the ip-generate command. This works fine, but the result would be better if we might have dependency checking in the build so that we could regenerate the QSYS systems only when their component HDL have changed. For example, this is possible with quartus using "quartus_sh --determine_smart_action". Does anyone know of a similar possibility with the QSYS scripted generation - aka ip-generate? Thanks for any suggestions, Jeff
