10 years agoqsys sdram controller address mapping
Hi, In a qsys design I'm using the SDRAM Controller Core to control either a 2Mx32 or 4Mx32 SDRAM. My goal is to use a common FPGA image rather than have an image that is unique for each size ...
10 years agoThanks for the response, and for confirming what I suspected. If I decide to try to fix the address map, I suspect I will try to create a bridge. It seems like this could be a very simple shim between slave and master. Hopefully it wouldn't even need any registers, just a passive rewiring of the address bus.
