qsys script not working
Hey!
I have generated a tcl script for qsys system from the platform designer to use it in another project.
when I run the script, I got this error:
Error:can't find package qsys exactly 21.4
I tried running it in the tcl consule with qsys-script command but it says that it is an invalid command.
How to fix this?
- sstrell
What's the full command you are using? And do you have version 21.4 installed as mentioned in the message?
- AhmadZaklouta
I am selecting the tcl file from the tcl console and click on run.
yes, I have quartus prime pro 21.4
- SyafieqS
Hi Ahmad,
I found similar issue as link below, perhaps it helps
- SyafieqS
Ahmad,
May I know if there is any update?
- AhmadZaklouta
The tcl doesn't work. I just copied the whole system to another project
- SyafieqS
Ahmad,
Can you try to delete qdb recompile and reinvoke tcl command, or alternatively create a brand new project and execute the script.
- SyafieqS
We do not receive any response from you to the previous reply that I have provided, thus I will put this case to close pending. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
