12 years agoQSYS output (synthesis) directory workaround?
Hello All, We recently started upgrading from SOPC builder to QSYS. There is one(...) big annoying difference between the two systems: When generating a system QSYS copies ALL files into a synt...
12 years ago --- Quote Start --- Hang on, read your original request above - you wanted to avoid copying the source to the Qsys directory :) --- Quote End --- Let me rephrase: SOPC adds the file paths to the project qsf file without copying them :) --- Quote Start --- If you don't like my use of environment variables, there are two other solutions; 1. The ::quartus() array is available in most of these tools. If the environment is inherited when one tool starts the next, then you can put a variable in ::quartus and access it in the downstream tools. 2. You can create a fake generic/parameter using set_parameter, and then access it later using get_parameter Personally I see no harm in setting a few environment variables :) --- Quote End --- Thanks Dave, I will give this a try
