12 years agoQSYS output (synthesis) directory workaround?
Hello All, We recently started upgrading from SOPC builder to QSYS. There is one(...) big annoying difference between the two systems: When generating a system QSYS copies ALL files into a synt...
12 years agoHi Dave,
Thanks for the answer. If I understand correctly you use an environment variable in your .qip files. This is not as easy-to-use as it was with SOPC builder but at least it is a lot easier than manually editing the qip file generated by QSYS. For the time being this will work just fine but I hope Altera will fix this in future versions. Thanks, Jo
