Qsys now Platform designer, no error , error at same time, on wrong Avalon parameter.
Thanks for providing the test case. For the case where byteenable is moved to avalon_slave, the Platform Designer generates error when the byteenable is set to 2 and Bits per symbol is set to 16, which is correct. The byteenable should be 1 if the Bits per symbol is set to 16 and read/write data width is 16.
When the byteenable is moved to conduit_end, byteenable is set to 2 and Bits per symbol is set to 16, the software did not generate any error message. The byteenable is generated as an input to the conduit_end. No error message is generated because the data transfer proceeds as if all byteenable are asserted if the interface does not have a byteenable signal.
- RRomano0017 years ago
Contributor
I don't understand if you say me this is ok or recognize it don't reveal an hardware error.
