10 years agoQSYS info run tcl script
Hello, I notice when I when I use QSYS and hit generate, during the build screen, there are lots of little notes along the lines of: info: Remember to run the IP_name.tcl script after synth...
10 years agoHello,
To clarify now, I get this message during the Qsys generate: "Info: p0: Remember to run the first_OV5640_to_hdmi_mem_if_ddr3_emif_p0_pin_assignments.tcl Info: p0: script after running Synthesis and before Fitting." SO, as per the linked threads, I've run Anayisis and Synthesis. I then used the tcl console to cd to the directory with the scripts, and run source first_OV5640_to_hdmi_mem_if_ddr3_emif_p0_pin_assignments.tcl However, it spits out a bunch of errors for the script, see attached. Any advice what I'm doing wrong as I try to run this? Thank you.
