10 years agoQSYS info run tcl script
Hello, I notice when I when I use QSYS and hit generate, during the build screen, there are lots of little notes along the lines of: info: Remember to run the IP_name.tcl script after synth...
10 years ago --- Quote Start --- When I'm building my own project, are these tcl scripts something I should be doing? --- Quote End --- The simplest way to run these generated files is to use pre-flow scripts. I've posted examples before ... I think the zip files in these posts have the scripts ... http://www.alteraforum.com/forum/showthread.php?t=45927 http://www.alteraforum.com/forum/showthread.php?t=43992 Cheers, Dave
