10 years agoQSYS info run tcl script
Hello, I notice when I when I use QSYS and hit generate, during the build screen, there are lots of little notes along the lines of: info: Remember to run the IP_name.tcl script after synth...
10 years agoYes, you do need to run these. So far I've only seen them associated with memory controllers and the HPS in an SoC. They set things like voltage levels, termination resistors and I/O standards for the pins.
