CHebl's avatar
CHebl
5 years ago
QSys Get component instance name in generation callback
I currently want to generate timing constraints for a custom QSys component.
To write the constraints correctly I need to include information about the hierarchical design to only constraint nets in the specific component, since other components might differ in parameters and thus in the genrated timing constraint (different generated clocks, etc.).
For this I would like to get the instance name in the generation callback in QSys, which I haven't been able to do.
Using the parameter of the generation callback doesn't work, since it yields he module name and using HDLINSTANCE_GET_GENERATED_NAME doesn't work, cause it only generates unique names inside a wrapper, which will repeat when you instantiate multiple wrappers and thus don't work for the constraints.
Do you know a way to get the instance name?
Many thanks for help.
  • SyafieqS's avatar
    SyafieqS
    Hi Christian,
    Assuming I understand your question correctly, you probably can get use of RTL Viewer or Technology Map Viewer post-fit to get the instance name after synthesis
