CHebl
5 years agoQSys Get component instance name in generation callback
I currently want to generate timing constraints for a custom QSys component.
To write the constraints correctly I need to include information about the hierarchical design to only constraint ne...
SyafieqS
5 years agoHi Christian,
Assuming I understand your question correctly, you probably can get use of RTL Viewer or Technology Map Viewer post-fit to get the instance name after synthesis
