10 years agoQSys Error on custom IP ST connection
Hi, I am quite new to QSYS, I started using at September and I got some result. On Linux PLL cannot be edited and don't save so I open XML file and I set manually parameter. I sat down do aft...
10 years ago --- Quote Start --- Could you post some higher res screenshots? The attached images are only 400px x 200px, so it is impossible to see anything in them. --- Quote End --- Hi, thank for kind and prompt reply, images where attached as files but forum code I see resized them, I try with image embedding only of large one, the smallest I think are readable. I forgot on preceding post target board is BEmicro MAX10 with an attached RGB TFT parallel LCD http://www.alteraforum.com/forum/attachment.php?attachmentid=11631&stc=1 Ok brute force against forum... Zipped file contain original images. How can I insert hi resolution on post?
