12 years ago
Qsys doesn't open
I tried to open Qsys from tools, but it only has a starting screen then nothing happens...
    You should provide more information. What version are you running? What OS? Have you checked task manager (alt ctrl del or ctrl shift esc). Have you checked your resource manager (Win7: from Task mgr, Performance Tab, Resource Monitor Button] to see if Qsys is chugging away at something?
    Altera generates a few different debug logs located in the altera/[version]/[program] directory. See if you can find one for Qsys or Quartus II.
    Does your software point to a license file (free or paid)? Has that license file (or server) moved/changed? Quartus II started running very slow for me. It was the free version but I had a license still which was pointing to a server that was moved and wasn't working anymore. Quartus took 10 minutes to compile a 1 minute project.
    Had the same issue on a 64 bits Linux installation, there were no logs, but I managed to launch Qsys from the commandline with:
    /quartus/sopc_builder/bin/qsys-edit
    and the following error came up:
    2014.04.18.13:59:44 Info: Doing: qsys-edit
    Exception in thread "main" java.lang.UnsatisfiedLinkError: /opt/Altera/13.1/quartus/linux/jre/lib/i386/xawt/libmawt.so: libXtst.so.6: cannot open shared object file: No such file or directory
    at java.lang.ClassLoader$NativeLibrary.load(Native Method)
    at java.lang.ClassLoader.loadLibrary0(Unknown Source)
    Problem is Quartus is on a 64 bits Linux while Java here is looking for a 32 bits (i386) version of a library, solution is to install it with:
    sudo apt-get install libxtst6:i386
    Solution came from http://stackoverflow.com/questions/17355863/cant-find-install-libxtst-so-6
