12 years agoHad the same issue on a 64 bits Linux installation, there were no logs, but I managed to launch Qsys from the commandline with:
/quartus/sopc_builder/bin/qsys-edit and the following error came up: 2014.04.18.13:59:44 Info: Doing: qsys-edit Exception in thread "main" java.lang.UnsatisfiedLinkError: /opt/Altera/13.1/quartus/linux/jre/lib/i386/xawt/libmawt.so: libXtst.so.6: cannot open shared object file: No such file or directory at java.lang.ClassLoader$NativeLibrary.load(Native Method) at java.lang.ClassLoader.loadLibrary0(Unknown Source) ... Problem is Quartus is on a 64 bits Linux while Java here is looking for a 32 bits (i386) version of a library, solution is to install it with: sudo apt-get install libxtst6:i386 Solution came from http://stackoverflow.com/questions/17355863/cant-find-install-libxtst-so-6
