13 years agoI haven't tried with only one controller. You could be right that the fact that I use two controllers confuse Qsys. Or it could be that Qsys is confused because the controllers are not on the top level.
Anyway, the work-around I use at the moment is the following: - Open the top level Qsys system - In the Generation tab, select "Create testbench Qsys system: Standard, BFMs for standard Avalog interfaces" - Press generate - Open the generated Qsys testbench system - Delete the Conduit BFMs connected to the memory interfaces - Insert 2x of Altera DDR3 Memory Model for UniPHY, and connect them to the memory interfaces - And finally, generate simulation model for the testbench Qsys system
