13 years agoIf all you need is a model of the DDR3 memory, the memory makers often have that. Micron for example has verilog models for many DIMMs and individual SDRAMs. Just go to their webpage, select the correct product type, etc, pick something close to what you configured your IP for (or download the model and configure the IP to what the Micron spec says) and then run it. This works fine for me.
