9 years agoQsys disable interface based on parameter
I have a VHDL component packed as Qsys Component Editor and I need to disable interface based on parameter set by user. I have used naive approach and have this in TCL:
add_parameter C_MDIO BOOLEAN false
set_parameter_property C_MDIO DEFAULT_VALUE false
set_parameter_property C_MDIO DISPLAY_NAME C_MDIO
set_parameter_property C_MDIO TYPE BOOLEAN
set_parameter_property C_MDIO UNITS None
set_parameter_property C_MDIO DESCRIPTION "Enables MDIO Controller"
set_parameter_property C_MDIO HDL_PARAMETER true
# # connection point MDIO_MASTER#
add_interface MDIO_MASTER conduit end
set_interface_property MDIO_MASTER associatedClock MDIO_CLK
set_interface_property MDIO_MASTER associatedReset ""
set_interface_property MDIO_MASTER ENABLED
set_interface_property MDIO_MASTER EXPORT_OF ""
set_interface_property MDIO_MASTER PORT_NAME_MAP ""
set_interface_property MDIO_MASTER CMSIS_SVD_VARIABLES ""
set_interface_property MDIO_MASTER SVD_ADDRESS_GROUP ""
add_interface_port MDIO_MASTER MDIO_IN mdioin Input 1
add_interface_port MDIO_MASTER MDIO_OUT mdioout Output 1
add_interface_port MDIO_MASTER MDIO_T mdiot Output 1
This causes following error: Error: get_parameter_value not allowed during GLOBAL
while executing
"get_parameter_value C_MDIO "
invoked from within
"set_interface_property MDIO_MASTER ENABLED "
I kinda get why it isn't allowed (so that's not my question). What I'd like to know is how should I do it when I want to enable/disable certain interfaces based on user's choice in component configuration in Qsys.. Thanks for any help :)1 Reply
OK, I've solved it.
You need to create an elaboration callback and change the property there:set_module_property ELABORATION_CALLBACK elaborate proc elaborate {} { set_interface_property MDIO_MASTER ENABLED }
