11 years agoThanks linas, that hint was what I needed.
For those coming across this later, this is what I ended up doing. I downloaded the Micron DDR2 model from here: http://www.micron.com/-/media/documents/products/sim%20model/dram/dram/3944512mb_ddr2.zip I modified ddr2_parameters.vh to include `define sg37E `define x16 I then created a qsys system with just a DDR2 controller https://www.alteraforum.com/forum/attachment.php?attachmentid=9706 (burst length was increased to 8) https://www.alteraforum.com/forum/attachment.php?attachmentid=9707 Generation included simulation but didn't include producing the test bench. https://www.alteraforum.com/forum/attachment.php?attachmentid=9708 Next was my test bench. (Yes I know there are better ways of driving the signals. This is just a quick hack)`timescale 1 ps / 1 ps
module microntest_TB ();
reg amms_address = 23'd0; // amms.address
reg amms_write = 1'd0; // .write
reg amms_read = 1'd0; // .read
reg amms_beginbursttransfer = 1'd0; // .beginbursttransfer
wire amms_waitrequest_n; // .waitrequest_n
wire amms_readdata; // .readdata
wire amms_readdatavalid; // .readdatavalid
reg amms_writedata = 64'd0; // .writedata
reg amms_byteenable = 8'd0; // .byteenable
reg amms_burstcount = 3'd0; // .burstcount
wire ext_local_refresh_ack; // ext.local_refresh_ack
wire ext_local_init_done; // .local_init_done
wire ext_reset_phy_clk_n; // .reset_phy_clk_n
wire mem_mem_odt; // mem.mem_odt
wire mem_mem_clk; // .mem_clk
wire mem_mem_clk_n; // .mem_clk_n
wire mem_mem_cs_n; // .mem_cs_n
wire mem_mem_cke; // .mem_cke
wire mem_mem_addr; // .mem_addr
wire mem_mem_ba; // .mem_ba
wire mem_mem_ras_n; // .mem_ras_n
wire mem_mem_cas_n; // .mem_cas_n
wire mem_mem_we_n; // .mem_we_n
wire mem_mem_dq; // .mem_dq
wire mem_mem_dqs; // .mem_dqs
wire mem_mem_dqs_n; // .mem_dqs
wire mem_mem_rdqs_n; // .mem_dqs
wire mem_mem_dm; // .mem_dm
reg clk_clk = 1'd1; // clk.clk
reg sreset_reset_n = 1'd1; // sreset.reset_n
reg greset_reset_n = 1'd1; // greset.reset_n
wire sysclk_clk; // sysclk.clk
always begin
# 10000
clk_clk <= !clk_clk;
end
always @ (posedge ext_local_init_done) begin
# 990000
amms_write = 1'd1;
amms_writedata = 64'h1234_5678_1122_3344;
amms_address = 8'h2;
amms_byteenable = 8'b11111111;
amms_beginbursttransfer = 1'b1;
amms_burstcount = 3'd1;
# 13333
amms_write = 1'd1;
amms_writedata = 64'hAABB_CCDD_AAAA_BBBB;
amms_address = 8'h13;
# 13333
amms_write = 1'd1;
amms_writedata = 64'h1111_2222_3333_4444;
amms_address = 8'h24;
# 13333
amms_beginbursttransfer = 1'b0;
amms_write = 1'd0;
amms_writedata = 64'h0000_0000_0000_0000;
amms_address = 8'h0;
amms_byteenable = 8'b0000_0000;
# 400000
amms_read = 1'd1;
# 13333
amms_read = 1'd0;
# 400000
amms_read = 1'd1;
# 13333
amms_read = 1'd0;
end
microntest uut (
.amms_address (amms_address), // amms.address
.amms_write (amms_write), // .write
.amms_read (amms_read), // .read
.amms_beginbursttransfer (amms_beginbursttransfer), // .beginbursttransfer
.amms_waitrequest_n (amms_waitrequest_n), // .waitrequest_n
.amms_readdata (amms_readdata), // .readdata
.amms_readdatavalid (amms_readdatavalid), // .readdatavalid
.amms_writedata (amms_writedata), // .writedata
.amms_byteenable (amms_byteenable), // .byteenable
.amms_burstcount (amms_burstcount), // .burstcount
.ext_local_refresh_ack (ext_local_refresh_ack), // ext.local_refresh_ack
.ext_local_init_done (ext_local_init_done), // .local_init_done
.ext_reset_phy_clk_n (ext_reset_phy_clk_n), // .reset_phy_clk_n
.mem_mem_odt (mem_mem_odt), // mem.mem_odt
.mem_mem_clk (mem_mem_clk), // .mem_clk
.mem_mem_clk_n (mem_mem_clk_n), // .mem_clk_n
.mem_mem_cs_n (mem_mem_cs_n), // .mem_cs_n
.mem_mem_cke (mem_mem_cke), // .mem_cke
.mem_mem_addr (mem_mem_addr), // .mem_addr
.mem_mem_ba (mem_mem_ba), // .mem_ba
.mem_mem_ras_n (mem_mem_ras_n), // .mem_ras_n
.mem_mem_cas_n (mem_mem_cas_n), // .mem_cas_n
.mem_mem_we_n (mem_mem_we_n), // .mem_we_n
.mem_mem_dq (mem_mem_dq), // .mem_dq
.mem_mem_dqs (mem_mem_dqs), // .mem_dqs
.mem_mem_dm (mem_mem_dm), // .mem_dm
.clk_clk (clk_clk), // clk.clk
.sreset_reset_n (sreset_reset_n), // sreset.reset_n
.greset_reset_n (greset_reset_n), // greset.reset_n
.sysclk_clk (sysclk_clk) // sysclk.clk
ddr2 ddr_inst (
.ck (mem_mem_clk),
.ck_n (mem_mem_clk_n),
.cke (mem_mem_cke),
.cs_n (mem_mem_cs_n),
.ras_n (mem_mem_ras_n),
.cas_n (mem_mem_cas_n),
.we_n (mem_mem_we_n),
.dm_rdqs (mem_mem_dm),
.ba (mem_mem_ba),
.addr (mem_mem_addr),
.dq (mem_mem_dq),
.dqs (mem_mem_dqs),
.dqs_n (mem_mem_dqs_n),
.rdqs_n (mem_mem_rdqs_n),
.odt (mem_mem_odt)
endmodule
This code, instantiates the qsys module then connects it to the Micron memory model. Finally, I put a script together to run the simulation set TOP_LEVEL_NAME "microntest_TB"
set QSYS_SIMDIR "microntest/simulation"
source $QSYS_SIMDIR/mentor/msim_setup.tcl
dev_com
com
vlog ddr2.v
vlog microntest_TB.v
elab
add wave *
run 80 us
Hopefully that is of help to someone.
