14 years agoPerhaps the GUI isn't poking the right value into the .tcl file for your component. If you open up the .tcl file for it and search for that waitrequest_n signal it should have "waitrequest_n" listed beside it. If that's not the case manually edit that line so that the right signal type is present which should remove the need to hack the generated HDL.
