9 years agoQsys Custom Component Files Overwritten
I have a number of Qsys custom components used in a Qsys system. Some share the same filenames (but for different source files). The result is that when they are copied to the Qsys synthesis/submodul...
9 years agoFiles with the same name must be in different locations. You can point to different locations for your IP using the options in the Tools menu (I believe, I don't have it open right now). There you can set the IP search paths you want for storing your HDL code and associated _hw.tcl files.
