Hi Daixiwen,
I got the same error while trying to create custom component with quartus version 13.1 in qsys which has parameter dependent address width.
I tried two cases to generate component but in both the cases i got same error that is "Error: Width of port av_d_addr_word_i/av_c_addr_word_i is invalid + (non-static) - (0) + 1 (must be an integer or parameter name)"
The tried case is in texts below.
// for case_1
// parameter for simulation purpose
parameter SIMULATION = 1'b0;
// parameter for specifying the memory depth in KBytes
parameter MEMORY_DEPTH_IN_KBYTES = 16;
// Local Parameter for memory depth in bytes.
localparam MEM_DEPTH_8 = ( MEMORY_DEPTH_IN_KBYTES * 1024 );
// Local Parameter for memory address width.(_8 prefix indicates this is for byte(8 bit)).
localparam MEM_ADDR_WIDTH_8 = clogb2( MEM_DEPTH_8 );
// Local Parameter for avalon slave component address width ( 32 bit aligned )
localparam AV_ADDR_WIDTH = ( MEM_ADDR_WIDTH_8 - 2 );
input [(AV_ADDR_WIDTH-1):0] av_d_addr_word_i;
input [(AV_ADDR_WIDTH-1):0] av_c_addr_word_i;
function integer clogb2;
input integer depth;
integer i;
integer result;
begin
result = 0;
for ( i = 0; 2 ** i < depth; i = i + 1 )
begin
result = i + 1;
end
clogb2 = result;
end
endfunction
For case_2
input [clogb2((MEMORY_DEPTH_IN_KBYTES * 1024)-2) -1 : 0] av_d_addr_word_i;
input [clogb2((MEMORY_DEPTH_IN_KBYTES * 1024)-2) -1 : 0] av_c_addr_word_i;
integer i;
integer result;
begin
result = 0;
begin
result = i + 1;
end
clogb2 = result;
end
endfunction
Is there any other way to do this!
Will be looking forward to your reply.
Hitesh.
