13 years agoSo I actually figured out what was wrong... kind of. I didn't realize you needed a top level file to kind of interface between the actual file and qSys. Seems a bit strange since it was able to populate the list of signals but whatever. I now have definitely working conduits, however I guess my avalon MM implementation is off. This is my actual code I've been using to try to figure out what is going wrong. Top level included for completeness' sake.
I'm not trying to blow off your simulation comments (again) but this seems to be a protocol implementation? Manythanks Notes: This is being used to try to talk to RAM initialized with data in it from a .hex Code gets hung up waiting for WaitRequest enable is connected to a debounced PB active high. LEDs are active low Logic:module ReadRAM(clk,reset,waitR,readData,read,addr,BE,enable,led1,led2,led3);
//Avalon Signals
input clk,reset,waitR;
input readData;
output reg read = 0;
output reg BE = 'b1111;
output reg addr = 'h00000000;
//Peripheral Signals
input enable
output reg led1 = 1;
output reg led2 = 1;
output reg led3 = 1;
integer caseMaster = 0;
reg data = 'h00000000;
always @(posedge clk) begin
case(caseMaster)
0: begin //check enable
if(enable==1) begin
caseMaster = 1;
end
end
1: begin //set up registers & go
addr = 'h00000000;
read = 1;
led1 = 0;
caseMaster = 2;
end
2: begin //wait for RAM to be ready and pull data
if (waitR == 0 begin)
led2 = 0;
data = readData;
read = 0;
caseMaster = 3;
end
end
3: begin //if data is good, ping led3. Reset caseMaster
if (data != 'h00000000) begin
led3 = 0;
end
if (enable == 0) begin
caseMaster = 0;
end
end
endCase
end
endmodule
What seems to be happening is waitRequest stays high and never comes back down, which means it is never indicating it is ready. This seems to me that it could only be a result that the read request isn't getting there, but I don't understand how that is the case if it is mapped appropriately in the component editor. Top level connecty file module readRAMInt(clock,reset,waitRequest,readData,
read,address,byEn,
input clock,reset,waitRequest;
input readData;
output read;
output byEn;
output address;
input enable;
output led1,led2,led3;
wire wClock, wReset,wWaitRequest;
wire wReadData;
wire wRead;
wire wAddress;
wire wByEn;
wire wEnable;
wire wLed1,wLed2,wLed3;
ReadRAM u1(.clk(wClock),.reset(wReset),.waitR(wWaitRequest),
.readData(wReadData),.read(wRead),.addr(wAddress),.BE(wByEn),
.enable(wEnable),.led1(wLed1),.led2(wLed2),.led3(wLed3);
//Avalon Inputs
assign wClock = clock;
assign wReset = reset;
assign wWaitRequest = waitRequest;
assign wReadData = readData;
//Avalon Outputs
assign read = wRead;
assign address = wAddress;
assign byEn = wByEn;
//User Inputs
assign wEnable = enable;
//User Outputs
assign led1 = wLed1;
assign led2 = wLed2;
assign led3 = wLed3;
endmodule
