9 years ago
Qsys Avalon Streaming Sink in Component Editor
I am struggling with the Component Editor in Qsys.
I would like to use the SGDMA IP the produce a 64-bit Avalon stream from memory. This is done by 8 parallel streams of 8 bits (see screenshot). However, I am not able to produce the same waveform in my own component. The editor always drafts one input data of 8 bits (see screenshot). The data sink port is initialized with a 64-bit vector.
module avalon_interface (//inputs
                                 clock,
                                 resetn,
                                 ctrl_write_data,
                                 ctrl_read,
                                 ctrl_write,
                                 ctrl_address,
                                 in_sink_valid,
                                 in_sink_data,
                                 in_sink_sop,
                                 in_sink_eop,
                                 weight_sink_valid,
                                 weight_sink_data,
                                 weight_sink_sop,
                                 weight_sink_eop,
                                 weight_data_empty,
                                 out_source_ready,
                                 //outputs
                                 ctrl_read_data,
                                 in_sink_ready,
                                 weight_sink_ready,
                                 out_source_valid,
                                 out_source_data,
                                 out_source_sop,
                                 out_source_eop
    input                             clock;
    input                             resetn;
    input                         ctrl_write_data;
    input                             ctrl_read;
    input                             ctrl_write;
    input                      ctrl_address;
    input                             in_sink_valid;
    input         in_sink_data;
    input                             in_sink_sop;
    input                             in_sink_eop;
    input                                weight_sink_valid;
    input                      weight_sink_data;
    input                                weight_sink_sop;
    input                                 weight_sink_eop;
    input                         weight_data_empty;
    input                             out_source_ready;
    output                     ctrl_read_data;
    output                             in_sink_ready;
    output                            weight_sink_ready;
    output                             out_source_valid;
    output       out_source_data;
    output                            out_source_sop;
    output                            out_source_eop;
Do you have any suggestions what I have to change to get the same waveform as that of the SGMDA IP?
Thank you very much,
Jan
1 Reply
    Those eight 8-bit symbols the tools are showing are all part of the same streaming interface. The tool is showing you that the symbol size is 8-bits and the total data width is 64-bit (i.e. 8 symbols wide). To implement something similar your streaming data would need to be 64-bit bit wide, with a symbol size of 8 bits, and a total width of 8 symbols. So you would define your RTL with a 64-bit data port and in component editor you set the symbol size to be 8, and if I remember correctly the tool will figure out the port is 8 symbols wide automatically.
