10 years agoQsys and basic signals
Hello All. Have problem with simple project with qsys. I am use onchip ram, and want write to address 0x000_000 2 bytes. I am add in qsys altera master template, all connect and 0 errors,...
10 years ago2 simonkbrown
Hello. Thank you for you are answer. So i am try all my ideas write to on-chip memory with use qsys. My last step - i am remove all, add only onchip memory, all exports and try this - result every time same - signals from qsys not drived. May be you have little time for understand this process ? I am think for to many guys its be good help. In attach - sreen from qsys, top level and signaltap screen. Thank you for understand.
