10 years agoQsys and basic signals
Hello All. Have problem with simple project with qsys. I am use onchip ram, and want write to address 0x000_000 2 bytes. I am add in qsys altera master template, all connect and 0 errors,...
10 years agoOk, so you now have the address, clken, signals etc. To write a word to the memory you need something along the lines of:
process(clk) if (rising_edge(clk)) then addr <= addr + 1; clken <= '1'; chipselect <= '1'; write <= '1'; writedata <= X"1234"; byteenable <= "1111"; end if; end process; This will (assuming addr is initialised on a reset signal or similar) fill your memory with 0x1234 and increment the address every clock cycle. Obviously you can change the write data each clock cycle, or you can pause the write with setting "write <= '0'" when not ready. Basically to write a word, setup the address, chipselect, clken, write, byteenable and writedata signals, and keep them there for a clock cycle (the same clock that you clock the memory with). To read a word you need address, chipselect, and clken and the data will appear on the following clock cycle on the readdata bus.
