10 years agoQsys and basic signals
Hello All. Have problem with simple project with qsys. I am use onchip ram, and want write to address 0x000_000 2 bytes. I am add in qsys altera master template, all connect and 0 errors,...
10 years agosimonkbrown
Hello, Thank you for answer. Exactly yes - i am want write few bytes to on chip memory via VHDL and avalon mm bus. Now i am remove master template, export slave and have in entity next: Use this for write or read - this input pins i am dont understand what. Sorry , i am really want understand avalon bus working logic. Thank you for answer. entity hd_mem is port ( clk_clk : in std_logic := '0'; -- clk.clk onchip_mem_s1_address : in std_logic_vector(10 downto 0) := (others => '0'); -- onchip_mem_s1.address onchip_mem_s1_clken : in std_logic := '0'; -- .clken onchip_mem_s1_chipselect : in std_logic := '0'; -- .chipselect onchip_mem_s1_write : in std_logic := '0'; -- .write onchip_mem_s1_readdata : out std_logic_vector(15 downto 0); -- .readdata onchip_mem_s1_writedata : in std_logic_vector(15 downto 0) := (others => '0'); -- .writedata onchip_mem_s1_byteenable : in std_logic_vector(1 downto 0) := (others => '0'); -- .byteenable reset_reset_n : in std_logic := '0' -- reset.reset_n ); end entity hd_mem;
