11 years agoQSYS 15.0 hanging (hung, wedged, locked-up etc) when loading my design
Hi, I am experiencing some troubles with 15.0 qsys-edit becoming wedged when loading my 13.1 design. The qsys editor GUI becomes completely comatose with the "open system" dialog box visible. I...
11 years agoHi Jeff,
--- Quote Start --- I am experiencing some troubles with 15.0 qsys-edit becoming wedged when loading my 13.1 design --- Quote End --- The Qsys XML file and parameters might not be portable from 13.1 to 15.0. For example, take a look at this DE0-nano design http://www.alteraforum.com/forum/showthread.php?t=45927 I used an AlteraWiki script to convert the qsys_system.qsys XML file several versions of Quartus to Tcl, and then put conditional logic in the Tcl script. In your case, if you only plan on using one version of Qsys, you might want to try recreating your Qsys system from scratch using the 15.0 IP cores and see if you succeed. Yes, that is a complete pain and should not be required ... but you might be waiting for a response to your Service Request for a while, so you might have the time :) Cheers, Dave
