13 years agoQsys- BFM Testbench causing add_connection error
Hello- I'm having difficulties generating a testbench in Qsys. I have a system, comprised of a custom model, several altera stream test generator/checkers, and a few exported signals (among them, clo...
13 years agoA quick update- after contacting Altera support, I've confirmed that there's a problem with generating the interface for the Avalon-MM bridge, as well as the conduit (which wouldn't work under the 'generate standard Avalon interfaces' option in any case, apparently).
An Altera representitive is looking into the issue, but the provided short-term work around was manually create the testbench system, manually adding master/slave BFMs.
