12 years agoQsys - No output on anlayze synthesis files
I am having a strange problem in that QSYS is not outputing any messages when trying to run the Analyze Synthesis Files on a custom component. This is what it looks like on a successful synthes...
9 years agoI have absolutely the same problem!
Windows 8.1(64 bit) + quartus 13.1, 15.1 and 17.0.2.602 Also I tryed to install windows 10 + quartus 17.0.2.602 on clean HDD. I tryed to run qsys with "--debug", all that i see in "Analyzing Synthesis Files" window is (ALL Info strings are empty): Debug: set ALTERA_HW_TCL_KEEP_TEMP_FILES=1 to retain temp files Debug: Command: C:/intelfpga_lite/17.0/quartus\bin64/quartus_sh.exe -t C:/Users/Dima/AppData/Local/Temp/alt7388_7658326834931209417.dir/0004_sopcqmap/not_a_project_setup.tcl Debug: Command: C:/intelfpga_lite/17.0/quartus\bin64/quartus_map.exe not_a_project --generate_hdl_interface=C:/altera-309/zander_main/canc/hdl/can_acf.v --set=HDL_INTERFACE_OUTPUT_PATH=C:/Users/Dima/AppData/Local/Temp/alt7388_7658326834931209417.dir/0004_sopcqmap/ --ini=disable_check_quartus_compatibility_qsys_only=on Info: Debug: Command took 2.191s Info: Debug: Command took 1.520s
