11 years agoQsys - Base Address Problem
Hello everyone,
i have created a qsys-system with a state machine working as an avalon memory mapped master and a pio working as an avalon memory mapped slave. The Master uses 32bit for addresses and 16bit data. The slave uses a 2 bit address and 8bit data. The pio slave is connected to leds. Now the problem: If i use a base address for the slave like 00000000hex or 02000000hex than it seems to function as aspected but if i use a base address like 02000008hex nothing happen. If i try to set the base address to an address like 02000001, i get an error that the base address cannot be at 02000001 (02000000 or 02000008 are acceptable). Why can't i use base addresses like 02000008hex? thanks and regards, schlittk
