15 years agoQSF setting similar to Xilinx Prohibit
I would like to know if there is a QSF setting that is similar to the Xilinx Prohibit setting. The prohibit setting disallows the use of a pin location e.g. CONFIG PROHIBIT = "A10"; disallows the use of pin A10 The only setting I could find is reserve_pin but I am not sure if this does the same as I also have to set a driving value. If this is a similar setting what should I select for the driving value? Thanks, Devas
